Cant start older VCs
Hello
I am using Xp Pro SP 1 and cant start any older VC's like 2.1, 3.0 and 3.1.
Is there a known problem or a work around when using a Base Configuration from ABB for your laptop?
I have seen others using XP able to start older VC's, but for some reason I can not on the ABB supplied laptops (IBM T42P)
PACs Application Engineer
Hello Thomas,
Below I have inserted a few rows from the Release Notes of RobotStudio 3.1:
Supported Controller Versions
Full support
S4c/S4c+ with RobotWare 3.2/52, 4.0/100
Limited support
S4/S4c with RobotWare 3.0, 3.1 (3.0 is only supported for S4C). Linear jogging, View Robot at Target, Jump to Target, robot axis configuration support and automatic setup of external axes are not supported.RobotStudio hasn't got full support in the contoller until 3.2. Controller 2.1 is really only to use "as is". 3.0 and 3.1 is usually no problem to start but not fully supported. We have noticed that the more modern computer and operating system you have these problems you mention seems to be more frequent.
At the moment we have no work around for this.
Best regards
/Ulrika Mor?n
Ulrika Mor?n38418,40761574070
