graph control RAB 5.12
i am trying out the graph control.
i use
Double[] PX={1,2,3};
Double[] PY={3,2,1};
graph1.addpoint(PX,PY);
but when i execute the code, i do not see the graph, i tried different things like
graph1.refresh(), graph1.update() and so on, but i don't see nothing, only the axes, not the data.
Can we draw different lines in the graph with different colors?
can i have some info or a working example?
Any help?
when is there help available for all the new controls available from RAB 5.11?
P.S. maybe this is offtopic, but on one real controller i cannot use hyperterminal to debug memory management, i connect it to the console port, i can see the messages when booting and everything, but when i press "enter", i don't get the "->" arrow so i cannot type any commands. any idea? hardware failure?
on another controller it works fine, so it is not my cable or computer.
Is there a possibility to read the available memory of the FP and write it to a RAB screen?
Kind Regards
Peter
Peter12009-05-15 09:28:43
  • Hi Peter ...
    I have not tried this code in the RAB 5.12. Could you verify it works?
    Thanks
    Carlos Martinez
    ABB
  • kioog
    kioog ✭✭
    Hi carlos,
    the code works, i use RAB 5.12 on robotware 5.11.02.
    I forgot the define the plotstyle.
    I have a question about the graph control
    If i use:
    graph1.XAxis.minvalue=10;
    graph1.XAxis.maxvalue=0;
    the plot  is still plotted in X from 0 to 10.
    so is there another way to plot Xdata from 10 to 0 for example
    I want to do this, because i want to plot measuredata in function of a robotposition in search, but sometimes the movement is in +X and sometimes the movement is in -X, but i want to plot the measures from start to finish.
    For the moment i make the Xmeasures negative in case of -X searching so my plot plots well,
    but now i see negative X numbers on the plot, but if it is not possible another way i can live with that.
    Kind regards
    Peter
    Peter12009-05-15 13:16:43
  • Hi Peter,
    Can you send me the RAPID modules or data you are planning to graph?
    I can't promise anything, but we can see if there is a workaround ...
    BR
    Carlos Martinez
    ABB
  • kioog
    kioog ✭✭
    Hi carlos,
    i am reading a log file created in rapid by the robot on a background task that is recording the current robot position and an analogue input while moving the robot.
    the data in the logfile is for example:
    1/50/300
    2/55/250
    3/60/210
    4/65/400
    where the first data is datacounter, the second the robot X position, the third an analogue input from height sensor
    but when i am searching in the other direction my logfile is
    1/65/300
    2/60/250
    3/55/210
    4/50/400
    for the graph control i now read this logfile line by line, use the second data as Xvalues and the third data as Y-values.
    i did it before with drawline,drawellipse, drawstring and calculate the coord of drawing on the screen including scaling and labels on the axis, but is was alot of work.
    i created a 4th data with the position starting from 0, used this data as Xaxis to draw the lines on the screen and use the second data to show the labels ( for example Xmin=65 and Xmax=50.
    with the graph control it would be a lot easier and a little fancier.
    another question:
    when i used drawline, drawellipse and so on, when i leave my RAB window (for example to view "production window") and then go back to RAB window, my drawings are gone, i use the form.onpaint method to redraw them, is that normal behaviour and the right way to do it?
  • Hi Peter,
    How is all things going on?
    Carlos Martinez
    ABB
