Can not manual rau when Screen maker active
Mr.Robot
in ScreenMaker
I can not run manual when the screen maker page active.
Is it limitation?
Please guide me the sulotion for manual run when screen maker page active.
Thank you.
HiI think you are trying to press start button from the FlexPendant to start your proram, by keeping Screen maker page active. Any program you want to start in the FlexPendant you need to keep either Program editor or Production window active with a Program pointer.Instead ,You can try to bind your routine you want to run to the "RunRoutine" control of Screen maker and you can run the routine in the screen maker window by deploying into the FlexPendant. In this case you only need to have a Program Pointer in your program but may not keep either Program editor or Production window as active window. Hence above message will not appear.Regardssunil sabut2009-05-29 13:52:51Sunil Sabut
India Corporate Research
ABB - India0
- 858 RAPID Programming
