Heat Sink error [ArcWelding PowerPac]
Hi all,
I am new to this application area.
I have ARISTOROB 500 power source model with my S4 Controller.
I am getting the following error number.
Error No: 117206
                Welding equipment error
                Temperature in power source heatsink too
                high. Inverter is shut down until
                temperature switch is closed again.
Check:
                    Ensure that there is no obstacle that
                    reduces the cooling airflow that passes
                    through the heatsink of the powersource.
                    Wait until temperature switch is closed.
I have to replace the heat sink for this error. or airflow checking is enough.
Please help me to solve this error.
Thank you in advance.
Lingaa
