How to use UIInstructions in PC SDK
UIInstruction class under RAPID domain enables user to interact with Controller using       PC SDK Application. A sample solution has been given as attachement called-"UIInstructionSample".
  • The solution has been created in VS2008 envirionment and can be used for both Real as well as Virtual controller.
  • Please read the Help.pdf document before running the solution
For any clarification please contact
.webwiz/2846/UIInstructionSample.zip
SaleemJaved2009-06-03 11:35:01
Regards
Saleem Javed
  • If a PC client is displaying a dialog, but someone responds on the Flexpendant will the PCSDK return the abort event type?  I can't seem to get this to work.
    Thanks,
    Dan
