How to use IPC in PC SDK
Messages can be sent to RAPID task and can be received from the same using following classes under ABB.Robotics.Controllers.Messaging domain
webwiz/2846/IPCSample.zip
- Ipc.
- IpcQueue
- IpcMessage
A sample solution i.e. IPCSample has been attached, exhibits the process to send and receive message to and from a controller respectively. Solution is in C# and developed using VS2008. Make sure you have referenced RAB dll correctly.Solution is working for both Real & virtual controller.
So try it out!!!!!!webwiz/2846/IPCSample.zip
Regards
Saleem Javed
Saleem Javed
When I try to load the robot program to the VIRTUAL CONTROLLER I get the error message:The instruction IRMQMessage requires the option FlexPendant Interface ...(Also I tied to create my test robot module using RMQFindSlot) w/ the same error message.What is the best method to send events from Robot controller (a procedure) to a PC SDK application. (not as an answer to an event from PC to RbtController)?Thanks,RazvanRazvan Sirbu0
