Transform i VBA RS 3.0
When i use the transfom function i transfer from world coordinate.
when i recive my transform.x and transform.y
y= xpos of part and x = yPos
How do transfer from USC or localpos.
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi Klaus,
    I would put a little more effort into describing my problem if I where you. image I had to read your post 3 times before I understood what you where asking for.image
    'How to create objects in relative orientations
    Sub CreateTargetInLocalX()
        Dim tgt1 As Target
        Dim tgt2 As Target
        Dim tfmT As New Transform
        Set tgt1 = ActiveStation.Targets.Add
        tgt1.Transform.z = 1
        tgt1.Transform.Ry = UnitToAPI(rsQuantityAngle, 45)
        ActiveStation.UCS = tgt1
        Set tgt2 = ActiveStation.Targets.Add
        tfmT.z = ActiveStation.UCS.OffsetTransform.z + 0.5
        tgt2.OffsetTransform = tfmT
        ActiveStation.UCS = ActiveStation
    End Sub
