unexpect behavior (MoveL)
Drake
Hi, I have the following instructions:
FOR I FROM 1 TO 4 DO
MoveL a.....
MoveL b....
ENDFOR
and i expected that the robot would move to the points, but he doesn't reach the points, he start the following move instructing before ending the first...
Drake2009-06-17 00:33:38
Hi,If you are using zones in your move instructions this will cause the logical instruction to be executed before you think it would.See the RAPID overview manual (3HAC16580-1) chapter on Syncronisation with logical instructions.Hope this helps.RegardsGraemegraemepaulin2009-06-17 03:25:520
Thanks, it helped to solved the problem
This discussion has been closed.
