Robotware update
Dear All,
I am new to RobotSutdio IRC5. I don't know how to upgrade robotware installed on a real robot. Can anyone show me any reference or share with me how to do that?
Many thanks for your help.
  • Hi
    In system builder -> download to controller
  • Thank you very much.
    I tried to download the new system to the controller. But there is an error "There is no enough space in remote host".
    What can I do then? What kinds of file can be removed from controller?
    Many thanks
  • This happens to me all the time. What I've always done is put the robot into a cold boot through the Flex Pendant, under Restart-->Advanced. Then use your robot studio to download the system.
    Good Luck.
  • Hi, Sir,
    We just found that we have two robotware 5.10/5.11 and corresponding two robot systems in the controller. How can we load specified robot system then? We are new to robotware and robot system. Please help.
    Thanks
  • Hi
    you can delete robotware 5.10
  • Hi, everyone,
    Thanks a lot for your help.
    I downloaded a new robot system to the controller. When the controller is restarted, we get a message about "SMB" count modification. What happened? Should I do something to fix it?
  • [QUOTE=newform]Hi, Sir,
    Thanks
    [/QUOTE]
    If there is one or more systems on the controller already, you can load them by doing Restart-->Advanced-->X-Start. This will put you in the boot application to select any existing system to load.
  • Helli,
    "Restart-->Advanced-->X-Start" works well. Many thanks for the solution and your time.
This discussion has been closed.
