BootLoader Version and Flex Pendant
Jetman
Hi guys,
I have 6 IRC5 robots and the newer ones come with a BootLoader version 2.08 in the Flex Pendant and the older ones come with a BootLoader version 1.14f.
Can I switch Teach pendants between the Older and the Newer robots?
Does anyone know the difference between the 2 teach pendants? Except from the Hold to Run buttons that have been removed is there anything else? Faster Processor, more memory, etc?
Thanks,
Jet
Jet,
Janin Delorme, Ing. (P.Eng)
Yes you can interchange them. I believe the memory is the same but maybe a different processor architecture?? It may take a couple of restarts of the device to allow it to install the correct firmware from the controller.Russell Drown0
