RimbaseLib helper object [WebWare SDK]
I've been stumbled upon an issue while trying to create a helper object using the definition in the RimbaseLib (as in not using the activex control from AxRimbaseLib).
Is there a "recommended" way to do this?
I suspect some initializing has to be done in order to use the helper object, as i see all its properties raising exceptions, but i could appreciate a bit of help in figuring out exactly what to do.
I'm using webware sdk 4.6.32 with Microsoft Visual Studio 2005 in a C# application on Windows XP sp2.
I'm attaching print screens with the errors i get.
Thank you very much.
As a side note, while using the classic way, with a helper control on the form and then accessing its methods and all went smoothly.
yes the helper is an activeX object and cannot be created as normal object but need to be hold in a form.0
