Upgrading to 5.12, FP app. launch error
labu
I have a fairly big FP SDK application developped since 5.06 which I have upgraded without any issue up to 5.10, simply by updating the references to the RAB bin.
I have just done it to upgrade to 5.12 and got the application to fail at launch, not able to create my view with:
system.Reflection.TargetInvocationException
can not find method ABB.Robotics.Dcl.Jogging.CreateDclJogging().
Note that my code has not been changed at all.
This is a fairly hot topic as the delivery is for end of the week.
system.Reflection.TargetInvocationException can not find method ABB.Robotics.Dcl.Jogging.CreateDclJogging().
- What is your applicaiton doing?
- It seems that one of the methods you reference to is not there anymore. What it is funny is that the reported error belongs to a DLLs which does not belong to the FP SDK- could you email me a copy of your dlls? (the ones you are creating)RegardsCarlos Martinez
ABB0 -
Interesting but puzzling:
public TpsViewPicPacPal()
// Required for Windows Form Designer support
InitializeComponent();
MyCtrl = new Controller();
This line seens fairly standard and is the first line of my application but it throws the following:
L'exception ABB.Robotics.InternalException s'est produite
Message="MActhode introuvable : 'ABB.Robotics.Dcl.Jogging ABB.Robotics.Dcl.Jogging.CreateDclJogging()'."
Source="Dcl.Base"
ExtendedErrorInformation=" ABB.Robotics.InternalException at AddRef in ABB.Robotics.Controller/SDCCore.cs"
HResult=-2146232832
IsHResultValid=false
Name="ABB.Robotics.InternalException"
StackTrace:
A? ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String additionalinfo)
A? ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception)
A? ABB.Robotics.Controllers.Controller..ctor()
A? TpsViewPicPacPal.TpsViewPicPacPal..ctor() dans C:ProjetsVS2005Plateforme GTPURAB 5.12TpsViewBottlingview.cs:ligne 53
Any suggestion warmly welcomed
Which is the RW version of the system you are testing
Carlos Martinez
ABB0 -
Hi Carlos, got it right, been told the robot was upgraded to 5.12 and was not (5.10).
Problem solved. Thanks.
