Proyecting spot welding target
ARFECUA
I have a question.
I have a question.
IA'm projecting spot weld in Robot Studio. The coordinates values are manually load, because I have the teoric values . I didnA't found the way for to align the target with the piece in the same moment when I do it ( load the coordinates values manually).
When I worked with Robcad in the past and I could made this.
Somebody know the way for make this?
Thanks!!
- 858 RAPID Programming
