RS JT open format import
Options
spaik
Dear all,
RS allows several 3D format to read in, such as CATIA, IGS, SAT and so on.
JT is also allowed, but some versions are now allowed, such as JT ver.8.0
Actually RS4.0, when we change some files to RS library, then we can find a *.jt format
in the library support files. Those files were jt ver.6.4, which is not compressed and readable.
But most 3D converters make them as jt ver.8.0, which is compressed and it can't be
readable in RS5.xx.
So, is there any convert method from jt v8.0 to v6.4, or any method in RS itself?
or any plan to make jt add in converter?
Best & Kind Regards,
spaik
spaik
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
