Conveyor tracking setup errors
Options
I get two errors when trying to set up a conveyor tracking station in RS 5.12.
1st: When going in to 'Home/RobotSystem/Conveyor tracking/Setup' I directly get an error that says 'No useful workobjects could be identified. The setup cannot be completed successfully!'.
2nd: No mechanical unit (Conv1) could be found in 'Offline/Encoder Unit'.
What do I do wrong?
Best regards M Johnson
Hi,you need at least one workobject with the below settings:Move by Mechunit : your conveyorProgrammed : False0
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 737 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
