Points Question
Drake
Hi. I made a program that receives a pair of point (origin and destination) in a array (Pontos) and moves objects. Always passing the same points (confirmed several times) the movements aren't the same. It I would like to know why. It seems that it doesn't execute de SetDo synchronized. Thanks
http://www.youtube.com/watch?v=3UtMTprTHc0
3 examples:
Program:
PROC Path_1()
var num j := 1;
FOR i FROM 1 to nrElements DO !nr Elements in the array
MoveL Target_10,v1000,fine,tool0WObj:=wobj0;
MoveL Pontos{j},v1000,fine,tool0WObj:=wobj0;
SetDO PickSignal,1;
j:=j+1;
SetDO PickSignal,0; j:=j+1;
ENDFOR
Drake2009-08-13 13:24:52 0
When you simulate with eventmaneger you need at least 0.2 waittime from setting do and to the robot moves. Try out the time of waiting. dependst off CPU and grafic. Had same problem but solved it with waittime both before and after setting DOBR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
thks, that solved the problem
Happy to helpBR KlausBest Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 87 OmniCore
- 40 AppStudio
