RobotWare
lendyck
Is it possible to still obtain older versions of RobotWare? I have a backup from an IRB 6400R/3.0-100 with an S4C controller that I'd like to open with RobotStudio 5.12.
Thanks.
Thanks.
RobotStudio 5.XX does not support S4, S4C or S4C+. But, what some people do is that they create an IRC5 system for their robot in RobotStudio 5.xx and reuse the RAPID program and convert the configuration settings to allow it to be programmed using RobotStudio 5.xx. However, the 3m version of the 6400R is not supported by IRC5 so unfortunately, this is not possible in your case. But, you should, of course, be able to run the robot using RobotStudio 4.0Henrik Berlin
ABB0
