Multi Tasking
I want to create a program for 3 different pallettizing operations.
Should I use Multi Tasking for this or I can use a single task?
Each pallettizing has its own independent operation.
Please kindly guide me.
Lingaa
  • Hi Lin.
    Can't see why you want to use multitask for this. It must bee simple to make a small menu page with 3 option off witch pallaetizing operation you want too use.
    Best Regards KLaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Yes, three procedures called from a main should be sufficient.
    Called from I/O embedded in prog or TP menus.
