ScreenMaker Manual
ruiguima
in ScreenMaker
I'm having some trouble using the screen maker, were can I find some manuals?
For example: When I define a label with allow multiple state binding a num controller variable, every time I switch between the screenmaker application and the program data in the controller the program data always assume the value from the screen maker...
Thanks for the help.
BR
HiThere is an User Manual provided with the CTP release. You can find that in you application directory of your machine.The latest version of the manual will be shortly released with Screen Maker 5.12 during October 2009.RegardsSunilSunil Sabut
India Corporate Research
ABB - India0
