how can I get the 3d model information from SAT
zhengyou
when I import the 3d model from SAT, I want to read the coordinate of points on the surface of model. but I can't find RS provide this function. in the autocad, I can use function capture to get the information of coordinate of each point on the surface of model. how can I do like this? could anyone teach me? thanks. another question is why autocad can't read the sat file outputted by RS?
IA'm not sure I understand what you mean with points, but you will see the coordinates of the mouse click int the RobotStudio taskbar:The reason that AutoCad not can read the sat file is probably that RobotStudio use a newer version of ACIS then your AutoCad program. You can select what ACIS version you should use at export from RobotStudio:Best regards,
ABB Robotics0 -
thanks a lots0
- 5.5K RobotStudio
- 398 UpFeed
- 19 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 324 IRC5
- 63 OmniCore
- 813 RAPID Programming
- 6 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
