how know new surface from which original surface?
Options
zhengyou
I get a 3d MODEL which is consisted by several surfaces(called the original surface). when I divide this model into several parts by a series of parallel planes, each part has its new surface(called the new surface). the question is :
the new face is belonged to a certain the original surface, but they have different index numbers.
so when I use RS 2008 to get the total area of a certain part, RS wiil give me a cetain area value with an index number. how can I know this new index number is belonged to which original surface? in other words, how can I know the new surface is belongde to which original surface? thank you!
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 348 IRC5
- 74 OmniCore
- 845 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
