s4 boot problems
Hello new to this forum and i hope to get some help.
I have a s4 whit a problem.
I got the out off memory in cfg so I booted the system.
Now when I try to start I got this note.
referece error TriggInt
Wrong syntax value not allowed
What is this and how can I solve it?
Thanks for any help an sorry for my bad English Smile
Om nA?gon vill svara pA? svenska vore jag glad..
  • Hello,Smile
    It seems that you missed an option called "Advanced Functions" while you booted the controller.Cry
    The instruction, TriggInt isn't an basic (elemently) command. I mean you can not use that instruction before you install the option above.
    When the option is installed, then you can load a program which contains Trigg command.
    You can also confirm it if there is any syntax errors.
    Hopefully You can make it. Clap
    BR,
  • Tnx
    The problem started when I run the latest backup after boot.
    I remember that I did not included Advanced
    motion
    Is that what you mean or is there a Advanced Functions to?
    Anyway ABB HA?kan is on the way Smile
