problem with pictureBox and AllowMultipleStates
Could you help me? I have got problem with pictureBox component in RAB 5.12. I use VisualStudio 2008. I used component PictureBox and I wanted to used AlowMultipleState.s
I changed the AlowMultipleState from "False" to "True". But It did not open window for StatesEditor .
 When I wanted to change properties States->Collection and in Members Add new State. It writed ErrorMessage "It is possible to add states until the property AllowMultipleStates is set to true".
Thank you for answer.
Radim
  • Hi Radim,
    We need to fix this designer issue. In the meantime, the workaournd is to write the code  which will let you change a set a properties based of a value. Are you interested in only changing the Image property?
    Carlos Martinez
    ABB
