VSTA Load Error
Any help here is greatly appreciated. I receive the following error when trying to load my VSTA app.
RobotStudio .NET exception: Unknown Error: Load Add-In
Base exception: FileNotFoundException
Could not load file or assembly 'ABB.Robotics.RobotStudio.CustomContracts, Version=1.1.0.0, Culture=neutral, PublicKeyToken=d4b3480564cc872e' or one of its dependencies. The system cannot find the file specified.
at ABBInternal.VstaServices.VstaAddIn.LoadAddInInProc()
at ABBInternal.VstaServices.VstaAddIn.Load()
at ABBInternal.StationManagement.VSTA.VstaCommands.VSTABrowser_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand()
Thank You for the help,
Rick
Rick Lemberg
Hi,Most likely an installation problem. Check for the file incl. version at the location of the picture (see below). If it is not there, you should repair your installation. (Note: On Windows XP the "Windows" folder may be called "WINNT")Henrik Berlin
ABB0
- 398 UpFeed
- 20 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 328 IRC5
- 65 OmniCore
- 821 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
