UAS
GaryRice
Does anyone know if UAS can be demonstrated in RS 5.12.
Regards
GARY
You can add the UAS user interface to the Quick Access Toolbar via the "Customize Commands" interface, see pictures below. This is not recommended for regular usage but if you want to demonstrated the UAS system it can be done. Normally, RS suppresses the UAS system for Offline controllers.Henrik Berlin
ABB0 -
Thanks Henrik,When you say "RS suppresses the UAS system for Offline controllers" do you mean that i can demo it but the changes wont have any effect on the controller?RegardsGARY0
Changes to UAS will not be saved when working in Offline. What you can do is to setup your users and the use the "Export" function. Then you can "Import" the list to the RC (real controller) on Online.
ABB0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
