help menu
candy
I follow the prompts to install the software,but the help menu just works.When I click the menu,there is not anything.
Is there some examples about the "ArcWelding"?I mean that on the base of installing ArcWelding_PowerPac_5.12.I feel that helpless and do not how to do.
Try to locate the help file on your disk. You should be able to find it in the folder "C:Program FilesABB Industrial ITRobotics ITArcWelding PowerPac 5.12Helpen"
ABB0
