Virtual Controller Error
newform
Dear All,
I run RobotStudio and got the follow error message. RobotStudio then just stops there. I
1. reboot my computer
2. reinstall RobotStudio
3. reinstall RobotWare 5.12
All these cannot fix the error. Does anyone have a solution for it?
Many thanks
Many thanks
What OS do you use? XP or Vista?32-bit or 64-bit?Do you get the problem with all RW-versions or any specific?What RS version are you on? 5.12 or 5.12.01?What RW version are you on? 5.12 or 5.12.01?Try to disable possible firewalls and virus scanner and see if that helps.Henrik Berlin
ABB0 -
I am using
1. 32bit XP
2. RW 5.12
3. RS 5.12
I just found that I got the problem when opening one specific system I ever created. Everything is fine when I open other system. Therefore, I need recreate the system. But I am just worrying that I may get the same problem in the future.
