Using Helper in .NET [WebWare SDK]
in WebWare
Hello! I am trying to get the WebWare Helper ActiveX working from a .NET application but I cannot register variable subscriptions.
Is this a known problem ?
The problem arise when I try to cast the object returned by VariableEventList to something useful like AxRimbaseLib.S4VariableSubscriptionListClass
/Robert
S4VariableSubscriptionListClass is a hidden member of Rimbase.lib and is not intended for public consumption.
You should interact with an instance of the class as follows:
Dim obj As New S4VariableSubscriptionList
Dim shtRetVal As Short
Dim varname As String
obj = AxHelper1.VariableEventList()
shtRetVal = obj.Add(strName, "num", 0)Russell Drown0
