Target with Noname
I use Target with NoName (mark with *) when I program real robot, is it possible to use that in RS?
When I sync to station it works wine, but other direction not, even though I rename targets similar that they look in object browser.image
My RS is 3.0
T.Petri
  • image
    RS 3.0 supports inline targets (*). Although all targets need to have a name as graphical object.
    When you sync a path from a real robot with inline targets, you get names like il1 and so on.
    If you create targets in Robotstudio, you need to select them in the object browser and then change the property "Inline" in the property browser to "TRUE"
    You can select them all together and change the property...
    regards
    Christian
    regards
    Christian
  • Petri
    Petri ✭✭
    Thanks , this is working fine image
    Regards
    Petri
