Routines().Type not working
I am trying to fill a listView control with the names of the Procedures, Functions and traps from a module.  I am able to fill the listView with the names but when I try and parse what type of Routine it is all I get from the Type parameter is "Routine {7168}" it should parse to SymbolTypes below in the code.  Is this a bug or am I doing it wrong?
      Try
        tasks = controller.Rapid.GetTasks()
        Modules = tasks(0).GetModules()
        TaskName = tasks(0).Name.ToString
        Routines = Modules(0).GetRoutines()
        Dim Number As Integer = Convert.ToInt32(Routines.GetUpperBound(0))
        ListView3.Items.Clear()
        Dim item As ListViewItem
        For i As Integer = 0 To Number
          item = New ListViewItem(Routines(i).Name.ToString)
          If Routines(i).Type = SymbolTypes.Procedure Then
            item.SubItems.Add("PROC")
          ElseIf Routines(i).Type = SymbolTypes.Function Then
            item.SubItems.Add("FUNC")
          ElseIf Routines(i).Type = SymbolTypes.Trap Then
            item.SubItems.Add("TRAP")
          End If
          ListView3.Items.Add(item)
        Next
      Catch ex As Exception
        MessageBox.Show(ex.Message.ToString, Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Information)
      End Try
