two different ways of building a multimove system
  I want to build a  multimove system with two robots and I find there are two ways.
One is :first,build a empty system,then via the "system builder"build a system ,at last add the system.
  The other is: first ,build a empty system,then"create system from layout".
  My problem is that ??sis there some difference between these two methods and what difference in them.Which method do I need to select.
  Thank you very much!
  • I recommend you to build the system via "Create System from Layout". This is by far more user friendly than using system builder.
    ABB
