programming
I am running the robot the first time.And I have programmed a simple program.But when I run the program,the result is that :
              Failed to start.
              Secure access control mechanism to reject this restriction.
So , I do not know how to do the next?
Would someone help ?Thank you very much!
  • Check the section
    Running in Production -> Basic Procedures -> Starting programs
    of the Operating Manual for IRC5 with FlexPendant. This is available in RobotStudio from the Help menu.
    ABB
  • Problems like this are typically due to
    * PP not set to Main
    * Motors not On (in Auto mode)
    * Enabling device not pressed (in Manual Mode)
    Try to follow the instructions in the manual to see if it helps.
    ABB
