Not enough mem so save problem?
Laro88
One of the few things that are certain is that I have plenty of mem & diskspace available.
There was two instances of RobVC checking on one of the CPUs, but killing them brute force did not help....
Anyone have some tips to save anyway when this happens? I have lost an hours work but I am getting used to that
Regards
Regards
The source of the problem is the following.....
When opening af project from a network share it works fine. However, if the network is periodically disconnected, ( like removing a laptop from a dock and switching to wireless ) then it is impossible to save to the network drive.
Save as to a local drive works. Aferwards saving to network share is possible (overwriting).
Laro882009-11-23 12:07:500 -
Thank you for bringing this to our attention. I have logged the problem in our change request database. Henrik Berlin2009-11-23 11:55:25Henrik Berlin
ABB0
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
