Save module
Is there any way you can save a module so that the module header is also changed like it was in the S4 system. In the S4 system  when you choose save as the module was saved with a new name and the module header was also changed.  For some reason ABB has changed this in the IRC5.
I can t see the reason why they did that.
When do you want the module to have one name on disc and another name if you load the module into a robot system?
Does anyone know a workaround for this?
