How to configuar MTC 750 Rotary unit
Johhn
Hi All
we have a welding station with IRB2400 and MTC750 positioner,
when the positioner turning to a position(etc.200deg) it will turn more degrees
and return correctelly .
I think it's because of
the speed too high
or Acc/Dec
or load too heavy
or breaker abating
how to proceed I could solve?
PLS help me body
Hi,Execute the program to a certain position, compare the joint value of the turn table in RobotStudio (use JointJog Tool) and the Virtual FlexPendant. Are they the same?Henrik Berlin
ABB0 -
Hi Henrik
we don't have the licence key of RobotStudio,so I can't simulate the programe on PC.Only way that is Jogging manually to test, but It's normal .no result.THX0 -
Hi,I just assumed you were using RS since the question was posted in the RobotStudio forum. I have moved the topic to the RobotWare forum.Henrik Berlin
ABB0 -
have you set the mechanical unit load for the rotating axis, i get strange movements like that if the value is a long way out.Command is MechUnitLoad0
Hi guysWe have solved that problem ! Because of the "MechUnitLoad",but it's on mechanical only not on parameter .We got a more poise to fit on the fixture for making balance.Just soTHX Berlin and mattdavisbest regards0
