IRC5P With Robot Studio 5.12
Fathi
Did anyone ever try to restore backup file from IRC5P(Actual Controller)to Robot Studio?
I tried number of time,but there is error when i perform restore backup file into IRC5P System (in my notebook)
Thank for your response
See Release Notes:
- Paint backups from RW 5.12.01 not compatible with RW 5.12.02 or laterRestoring a paint system backup from RobotWare 5.12.01 will cause SysFail for RobotWare 5.12.02
Workaround: Add the parameters described in release notes to the configuration files-Lack of Virtual Controller support for the Paint systems
Paint systems that are configured using the Paint package I/O option Discrete, Compact or Fieldbus, will result in a SysFail state.
Workaround: Re-create the system with the simulated I/O option.
- Only single robot setups supported for Paint systems
It is possible to create the system with System builder for both single & multi paint robot systems using Virtual Key & Paint option. But a System failure will occur starting the Multi paint robot system. Only Single paint robot system can be started.Best regards,
ABB Robotics0 -
Thank You Mr Ander Spaak for your kindly reply.Regardfathi0
