Failed to check program error.
Insight needed on this reoccuring error with RS 5.12.02.
"Failed to check program" is flagged when trying to apply changes in the offline editor.
Programs are able to be sync'd to the VC correctly without errors.
Changes will be made in editor and when appyling changes the error occurs.
I am able to save the changes and use that module and also am able to sync that module back to station without any problems.  Is this an error to be concerned with/
  • If you get this message, warmstart the Virtual Controller, that will most likely solve the problem.
    ABB Robotics
  • Or, perheps leave out accute letters. (Use only ANSI).
