Is there a line graph function available?
in ScreenMaker
Is there a line graph function available in screen maker?
Hello,There is a graph control available in ScreenMaker that supports line plotting.The x axis and y axis values need to be binded to a RAPID array.Adjust the max and min values of each axes.And custom action needs to be defined for the graph control where in a method called UpdateValues should be selected.0
Hello,I encountered a problem here.I have binded an array to to the X and Y axis.I have also defined the updateValues. However, I still can't see the graph.is there anything else need to be define?0
Is it possible to create a sample for me. So I can just refer to it. Thanks0
Hello,I have attached a screenmaker application along with the a mod file which consists of two rapid arrays.You can take a look at them.0
- 858 RAPID Programming
