Objects disappearing into "invisible wall"
Options
I have a station with several robots and objects. In some angles and views it seems like the objects are "sinking into" an invisible wall as I zoom closer with the mouse wheel.
Have I reached the outer limits of RobotStudio's known space or something similar?
br Tormod
Tormod2010-01-14 15:49:57
Tormod Henne
Senior Engineer
  • I, also have this behavior from time to time as I zoom, move or rotate views.
    Anybody has an idea?
    - Francois
  • Hi,
    it might help to set View Center on the robot for example, or another object that you want to have "in your you view".
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Ok, tried View Center and the problem disappeared, at least for now.
    Thanks, Niklas Clap
    Tormod Henne
    Senior Engineer
