Additional ARC Systems [ArcWelding PowerPac]
Hello Bertie ,You have to create a process template for the Arc1 and Arc2 process and put it in the process template folder. You also have to create a process defintion template for Arc1 and Arc2 and put it in the "RobotStudioProcessDefinition" folder under "Documents and Settings). Now you can import the process template in AWPP
BR
Thanks!
