VSTA Objects in Viewer
Options
Hello.
I have a question about objects made with a VSTA-macro during simulation. If the object is made during simulation by calling the macro from the event manager, it doesn't seem to be visible when the station is saved as viewer.
So is it possible to make new objects visible in the viewer? Does anyone have any solutions or ideas for this problem?
Thanks!
Thanks!
ItA's correct that objects made in a VSTA-macro not will be visible in the Station Viewer.The objects that should be visible in the Viewer must exist in the station when the simulation is started. So one workaround is to generate all your objects before you start the simulation, another is to use show/hide instead of macros.In RS 5.13 will this problem be solved.RS 5.13 is planned to be released around April-May this year.Best regards,
ABB Robotics0 -
Ok, good to know. Thanks for your answer!
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
