Events in VBA
Klaus
Is it possible to let VBA makes new events in event table and how.
Bets regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hello Klaus,
What you are asking for is not possible in the way I believe you mean. You cannot program VB-code to effect the EventTable.
What is possible though is to connect VB-events to ClassObjects, for example:
Private Sub Station_Close()
MsgBox "goodbye"
End SubAdd the above to a station project, then close the station...
Hope this gives some input, to your work.
Best regards
/Ulrika Mor?n
Support Engineer
Check also out how to use IO events in the topic "read output in VBA"/Martin Lundh
Product manager
ABB Robotics0
