Backup completed with errors [WebWare Server]
Hello everybody!
While doing a backup in ww 4.7 I get the result: "Completed with errors" and the resultcodes: 3112. 3102. The funny thing is that we have made no change to the datacollector, robots or the server softwares.
We have five S4 robots connected to this datacollector and we have the same problem on four of them, the fifth doesnA't have any problem.
Would be gratefull for any input what the problem could be.
/Andreas
Can you please do a screen dump on the backup result page according to example in the zip-file below. Thanks!
Lennart H0 -
Thank you for the reply and here are the dump.
and in better quality0
Try to delete the DUMP directory. Then retry backup. If still not working investigate the backup for "strange" files i.e files that normally isn't included in a backup.
Lennart H0 -
You can also try to enable the FTP-interface in the profile.
Lennart H0 -
The problem was solved by turning the ftp interface on how we missed this is a mystery.
Thanks for the help0 -
It is not a complete mistery, lennart is right to point these files
With S4X if you don't enable FTP we use RAP protocol (Native Robot Application Protocol) to transfer files, but RAP is not able to handle long files/directories names and is limited to 8.3 (dos standard) file namesIn you case you have a File or Directory which are longer than this then you had an errorFTP is a bit slower and a bit less reliable but it handles long file namesJCJC ALT2010-09-08 14:43:550
- 87 OmniCore
- 40 AppStudio
