Rapid Object Object Array Address
I have an array in my rapid that has a length of 20. I want to address all these points with a seperate rapiddatabindingsources and then link them to dataEditors.
This is possible in Screen maker, how can i do this using Flex Pendent SDK?
Or is there an easier way that im not aware of??
I have attached a screen shot of what i am trying to achieve. I have also attached copy of the source code from screen maker and from SDK below for the databinfing objects and data editors..
imagewebwiz/2737/screeshot.jpg
SCREEN MAKER
            this.dataEditor1.DataBindings.Add
            (new System.Windows.Forms.Binding("Text", new ABB.Robotics.ScreenMaker.Windows.Forms.SingleBindingSource
                (new ABB.Robotics.DataBinding.RapidDataObject("T_ROB1", "Globals", "xArray"), new ABB.Robotics.ScreenMaker.Windows.Forms.Index[] {new ABB.Robotics.ScreenMaker.Windows.Forms.Index(1)}), "Value", true, System.Windows.Forms.DataSourceUpdateMode.Never));
            this.dataEditor1.Font = ABB.Robotics.Tps.Windows.Forms.TpsFont.Font10b;
            this.dataEditor1.ForeColor = System.Drawing.SystemColors.ControlText;
            this.dataEditor1.Location = new System.Drawing.Point(279, 185);
            this.dataEditor1.Size = new System.Drawing.Size(80, 20);
            this.dataEditor1.Text = "dataEditor1";
FLEX PENDENT SDK
            // rapidDataBindingSource1
            this.rapidDataBindingSource1.DataSource = typeof(ABB.Robotics.DataBinding.RapidDataObject);
            rapidDataObject1.ModuleName = "Globals";
            rapidDataObject1.TaskName = "T_ROB1";
            rapidDataObject1.VariableName = "xArray";
            this.rapidDataBindingSource1.RapidDataList.Add(rapidDataObject1);
            // dataEditor1
            this.dataEditor1.BorderStyle = System.Windows.Forms.BorderStyle.FixedSingle;
            this.dataEditor1.CaretVisible = false;
            this.dataEditor1.DataBindings.Add(new System.Windows.Forms.Binding("Text", this.rapidDataBindingSource1, "Value", true));
            this.dataEditor1.Font = ABB.Robotics.Tps.Windows.Forms.TpsFont.Font12b;
            this.dataEditor1.Location = new System.Drawing.Point(369, 129);
            this.dataEditor1.Multiline = true;
            this.dataEditor1.ScrollBars = System.Windows.Forms.ScrollBars.None;
            this.dataEditor1.SelectionLength = 0;
            this.dataEditor1.SelectionStart = 0;
            this.dataEditor1.SelectionVisible = false;
            this.dataEditor1.Size = new System.Drawing.Size(160, 40);
            this.dataEditor1.TabIndex = 3;
            this.dataEditor1.TextAlign = System.Windows.Forms.HorizontalAlignment.Left;
  • The binding mechanism used by ScreenMaker is defined inside ScreenMaker files. You can use this mechanism as long as all all forms are ScreenForm instead of TpsForm.
    BR/Carlos
    Carlos Martinez
    ABB
