about simulation
candy
I have built many stations.There is a confused problem:
When I simulate,the speed is so fast -fleeting.Now ,I can not clearly see that every solder joint.Is there a set the simulation speed of the project,but I always failed to find.
Thank you very much!
Use TimeSlice mode and adjust the accuracy according to your needs, see below:
ABB0
- 40 AppStudio
