Error in Track Motion
Dear All,
I have created a system with IRB 4600 and a IRBT4004 track of length 19m.
I have created the work object also.
My robot is not positioned directly on the track, it is kept in a pedestal.
First i attached Robot to the track. then i moved the Robot to the desired position which i require.
The distance from the origin of Robotstudio to different places is shown below.
To Robot X=-701, Y=532, z=1280
Center of track where robot is placed x=-648.5, Y= -540.0, z = 374.5
Position of Work object is X=0, Y = 0,z =400
When i teach a point in the workobject, for example P100, the value it is showing in the Home is x=665.85,y=1226.71,1223.87
But when i run the robot it is going to a position where x=613.35, y=2299.31,2129.37
i found that the problem is the origin is still in the centre of the Track only. How can i change it to the Robot.
Pls help me to solve this problem.
Regards,
Jipin Jose
Hi,You need to set the "Task Frame" to the same position as your robot:
But when you move the Task Frame, the robot and the track will move the same distance. So after you have moved the Task Frame, you must move back the track and robot with "Set Position".In RS 5.13 have we changed this behaviour to make it more user-friendly.Best regards,
ABB Robotics0 -
Hi Anders,Thanks for your help.But when i do the set frames it is showing me an error called"could not obtain the mastership" it is keep on coming which makes me to do nothing after that.How can i solve this.Regards,Jipin0
When you place the Task Frame at the base of the robot, you should not change the Base Frame. So the error in your station was that you had moved the Base Frame of the track. I moved it back to x,y and z =0, then it worked.
Because of your "special designed" track you will have a warning about that the Base Frame in the system doesnA't match the values in the station, in your station you should ignore this warning.
ABB Robotics0 -
Hi Anders,Thanks alot for your help.Regards,0
