incorrect curve
Hi!<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I`m using "KOMPAS 3D"(v10) programm for 3d modelling and i have problems with imported to Robot Studio (v5.12) geometry. I have made screenshots (attached rar file below) to illustrate better:
webwiz/3339/incorrect_curves.rar
In a figure 1 you can see imported geometry, then i create curves using "border around surface" command - see figure 2,
and i have some curves created not on a surface and this is not correct. The path created from this curve you can see in fig.3 and you can compare it with a fig.4 where is shown a final path what i need, so i have to make a lot of modifications to get a result.
Using "border around bodies" can solve my porblem but i get a lot of targets i do not need (figures 5,6,7)
I have aslo attached geometry i` v tried to import ( i have saved them as...in KOMPAS 3D) .sat, .iges, wrl and m3d(KOMPAS file format)
- 88 OmniCore
- 42 AppStudio
