Tool Orientation
Has anybody had trouble when programming a double ended tool?
Both ends are of equal length and have been defined and using the same lines of code with different work objects
yet when rotating the grippers one side is aligned perfectly straight whilst the other is slightly off centre, is there any way to correct this?
Also how can i just rotate joint 4-6 without it affecting joints 1-3? im having issues with selecting the end of the tool and the space available for manouver
any help would be appreciated
