Remove Targets
Stijn
// Instance active station.
Station stn = Project.ActiveProject as Station;
// Remove the original target.
stn.ActiveTask.Targets.Remove(myTarget);
Logger.AddMessage(new LogMessage("My_Target_1 is removed!"));
MessageBox.Show("target_1 is removed");
I have to delete (remove) a target in the path of robotstudio with C#.
I'm now using the code below to remove the target in my workobject (wobj0), but how should I delete this target in my path ?
HiHere is one way to do it. I guess it will help you continue onPer Svensson
Consat Engineering0 -
Hi,Thanks for your help! I tested the code that you suggested and it works like you said.Regards,0
- 304 PowerPacs
- 2.8K Robot Controller
- 355 IRC5
- 74 OmniCore
- 850 RAPID Programming
- 26 AppStudio
