Error opening a previously working project
eiven
in ScreenMaker
Hi!
A made a projeckt.
Then i did somthing wrong. Not sure what is was. After deploying to VC the FP was blank; no ABB and no programs to run. I hope I removed the error i made.
Restart RobotaStudio.
Now pendant is working, my app i working, but I cannot open my project in ScreenMaker to continue working on it.
Is there anywhere O can change some code in a .cs file to make it work?
Does this error message tell us anything?
Is my Project lost for ever?
Eiven
A made a projeckt.
Eiven
Eiven
Win 7-64
RS 5.15RC1
Q9950 16gb
Win 7-64
RS 5.15RC1
Q9950 16gb
Further investigation revealed that there CAN be a problem om my Office Computer.
When I transferred everything to my LapTop the same project is working fine.
I can load a SM project file on LapTop but not on Stationary PC, ergo There is a problem with my stationary PC NOT SM or RS.
Sorry for tthe trouble.
Eiven
eiven2010-04-19 09:40:10Eiven
Win 7-64
RS 5.15RC1
Q9950 16gb0 -
Hi Eiven,This error could come when there is a mismatch in one of the versions when loading a project which contains application variables. ScreenMaker is loading a different DLL than required. We need to investigate a little more into this.In the meantime, let's try this work around:1. Restart RS2. Create a new project (connect to any robot and create an application variable). Save this project, so next times, you can open this project instead of creating a new one.3. Close this project4. Open your projectLet us know if this worksBest RegardsCarlos Martinez
ABB0 -
PD - Try frist to create a project with NO applicaition variables ....
Carlos Martinez
ABB0 -
Hi!
I did fix this. Cannot remeber clearly but I think the problems had someting to do with MS .NET framework.
Everyhting is working fine now.
Thanx.
Eiven
Win 7-64
RS 5.15RC1
Q9950 16gb0
- 858 RAPID Programming
